i’m increasingly moving towards flat bars, if for no other reason than it makes them easier to adjust.
i’ll try and explain; with riser bars, the back sweep is ‘on top’ of the rise, if you rotate the bars to tweak the back-sweep up or down a bit, you also effectively lengthen/shorten the stem.
it’s not a huge problem i admit, but i’ve got a shonky wrist or 2, and am finding it tricky to get comfy, so have become a bit obsessed with bar-adjustment.
(also, wide flat bars look great)
((also, flat bars give you more room for stuff like lights, speedo’s, bells, etc))
