I’m going to use a filler called Lecol 7500
This is one of the greatest products ever made for people who fit and finish (especially parquet) floors. It will not be suitable for hora’s needs though – when it cures, it’s completely inflexible, will crack and fall out.
That Draughtex stuff that Stoner linked, would be the best solution…and if you must fill the gap, you’d be better off doing it with “fillets” of timber – possible not a job for a DIYer – depends on what kit you’ve got…if the fillets can be machined with a V-shape, they can be whacked down with a hammer and then sanded flat.
Make sure the floor is already ventilated with air-bricks either side of the room before you do anything though.
Nice job with that parquet khani.
I don’t use drum sanders with parquet – instead using a gigantic orbital sander (because of block direction) and because I can charge a fair whack for the extra time it takes. 🙂
If you’re a DIYer, then bloody well done mate – that looks fantastic!!
