Hi all
14year old Fiat Punto, 45k miles, MOT due mid Nov. Had a service done last year which involved oil change etc, but it cost half as much as the car’s worth along with the MOT. This leaves me with a choice next month; go for MOT sans service, or bite the bullet and stump up for both.
Car is generally problem free. Battery will fail the drop test (it did last year, not replaced it as it’s been fine bar one or two push starts and I’m cheap), some dashboard lights occasionally pop up and then disappear of their own accord, it’s idling slightly rough so may need new plugs but tbh I’ll probably do that if needs be, tyres fresh, clutch occasionally judders which apparently might point to the main hydraulic system needing bled (been like this for years, not bothered fixing it yet)…
Is it worth stumping up the cash for a service? We’ll be running this car into the ground, could do with it lasting a couple of years probably.
WWSTD?
