I wouldn’t be too bothered with SS. Rust can be avoided with good waterproof grease like marine grease, and a bit of care and maintenance, plus avoid jet washing anywhere near bearings. Also, constant use keeps rust at bay. Sitting there unused in humid or damp conditions and it’ll rust up.
Chrome with good grease should hold up longer.
But yeah, if they’re going to be sitting out in the rain then maybe SS. Though the races may not be SS so could still rust there. Other things are going to rust too if not used much.
Or, you could go ceramic. Less grease needed. The balls won’t rust (the races might though). Lasts longer. Though been using them on jockey wheels and find they lock up at times from tiny bits of grit. I have to pull them apart, flush and clean, then they’re fine again. But still better than the stock SRAM jockeys which once seized up they’re knackered and no amount of cleaning gets them spinning again.
