I had been trying to diagnose a squealing and sticking problem with my Giant MPH3 front disk brake and finally (after 6 damned months)have discovered what was wrong.
I’m not looking for any assistance here but I think it’s worth noting my observation nonetheless.
Over six months my front brake had been a mess (squealing, piston sticking in caliper, pad not retreating from disk) and I had tried everything to settle it down. This fault probably applies to most types of disk brake.
During overhaul (caliper off, pads out, caliper disassembled, pistons removed, seals replaced, system bled etc) I noted faint rings on the side of the piston. I also noted marking on the inner face of the caliper in which the piston sits. I went back to the pads to find that the friction surface was ‘sloping’. What I now think is that when the brake is applied, the piston forces the pad onto the disk, but because the friction surface is not level, the pad effectively tries to force the piston to move ‘out of true’. What I mean to say here is that instead of moving in and out at 90 degrees to the plane of the disc (as per manufacture), the piston is being forced to move at – say – 85 degrees. This is why it is catching the caliper housing and causing the damage mentioned earlier. It is almost certainly where the squealing has come from.
I have bought several sets of MPH3 pads before which have not been level and now wonder what on earth is going on here.??? I never really gave it any thought until today. Surely all disk pads should have the same thickness throughout ?
