Hi Guys
I recently lost power in the front brake and had to bleed the system.
When I came to test the brake though I noticed that only one piston was moving freely. I’ve had this with other brakes before so lubed and cleaned the other piston but still the same.
I then sent the caliper off to SRAM and it has been returned to me without fault ? again, when I press the brake lever only one piston comes out ?
If I hold the one piston that works, the other piston does come out, but surely they should both work at the same time ? I know this is how my old XT brake worked.
I have been told that the piston on the side with the hose attached comes out and when it meets a restriction i.e the brake disk then the other side will come out ?
Does this sound right ?
Mitch
