I think this has cropped up on the forum before but might have been some time ago so may be some fresh data on this.
I have above Avid units and realised the rear had a lot less bite than the front. They've not had a huge amount of wear so was not expecting to have to replace pads or anything yet. When I dropped the pads out one side had a little, even wear but the other pad was down to nothing on one edge (so the pad was like a wedge – front to back). After some further tinkering I realised that the pistons were not coming out of the caliper evenly.
I found some advice on't net that suggested locking the "good" piston and pumping the brake lever to free the "bad" psiton. I tried this yesterday with zip ties and it seemed to work fine; with them on the "bad" piston seemed to be coming out perfectly well. However as soon as I drop the whole unit with new pads back on the bike it just reverts back to before; uneven presure and very little bite.
So, do I need to strip the whole caliper and re-furb it? If so what do I need? CRC have bleed kits but are they universal for all the Avid range? Do I also need new seals (?) internally in the caliper? Can you guess I've never done anything like this before? Anyone want to do it for me 😆
I have heard of this happening to people before but others who have had no trouble whatsoever with their Avid kit, so it must be fixable?
