As far as i understand this is a fairly common problem with all brake types, I have Juicy 3s, M760, Mono Mini's and M4s ans all have done it at some time, admittily the Juicys seem to do it the most regularly. I run sintered pads on all. If it is perticularly bad try taking the pads out and flatten / rough them up wityh a metal file (keep file flat on surface), also try swapping pads front to rear. Also check caliper alignment and disk surface for smoothness.
If a disk has got very hot it is possible to pick up small amounts of metal and wipe it across the surface.
And finally for squeeling make sure the spring that keeps the pads separated is not bent and running the wrong side of the disc. The four fingers of the spring should sit evenly either side of the disc
