I’ve got some Avid Elixer 7 Trail brakes on my Carbon Stumpy 29er. They squeal like a pig with the first sign of dampness.
I’ve read quite a lot and it’s hard to tell whether it’s the frame design or the brakes themselves that creates all the noise.
I was on the verge of swapping them to XTs but even at the cheap prices you can get them for, once you add in rotors mounts etc it ads up to quite a lot just for some noisy brakes.
So, the question is, has anyone swapped over / have any experience of the new Avis Centreline rotors? Apparently they reduce vibration and noise.
For £50 all in I’m thinking about giving them a go, but if I’m getting the same noise then I’ll just bite the bullet now and go XT.
FYI – brakes are well bled, calipers aligned, copperslip on back of pads, rotors pushed anticlockwise against bolts before tightening – not sure what else I can do
