I’ve knocked the outboard adjuster on my rear BB7 a few times, causing it to fall off. I’ve just pressed it back in, but it’s not seating properly. I’m not sure what’s causing it – maybe the aluminium clip is deformed. I realised it was a problem when trying to adjust the brakes tonight – the front one has indented clicks, but the rear one just kind of spins, and I never know if it’s moving the outboard pad or just spinning within the caliper housing. Anyway, would a replacement adjust help, and if so, where can I buy them? If not, presumably there’s damage to the caliper, so I’d have to buy a replacement brake…
