Scart to component thing which will give you S-Video type out and L-R sound which can go from aux to 3.5mm Jack. Sounds like with no digital out to start with it’s a good bet
winston – true it has the capability of being bidirectional, but many aren’t. Also true of cables – some don’t have all the pins connected.
Also, there’s a chance that only the TV tuner will output over the scart, not any external sources (PS3 and BD player). Not definite, but there are definitely some tvs that don’t route inputs to output.
Mind you – it’s about £2 to try 🙂
Edit – the RGB could just indicate that it is RGB compatible (some are just composite), so may still support audio. But if it’s not in the manual you may have to just try.
Done similar with the TOS link box shown.
Got it as the TV speakers were poo. Got it connected to an old pioneer amp and some wharfdale speakers.
Sounds MUCH better, the only downside is I’ve got no remote for the volume now, but if I have the TV switched to the PVR I can use the volume control on that its fine.
You can find those boxes on Amazon for about a tenner HERE
Re the Scart – well worth trying. On old TV’s there was definitely audio and video out but on a new one you’ll only know by trying. Cheap enough to be worth a go.
