Viewing 12 posts - 1 through 12 (of 12 total)
  • Attatching scaffold pole to two walls….
  • brack
    I have asked this before but due to the morons hacking into the site – that post has gone.
    So
    How do I attach a scaffold pole to either side of my brick outbuilding in order to make a secure bike hanger/rack.
    If I remember correctly someone pointed me to scaffolding supplies but they don’t seem to have what I am looking for??
    wwaswas
    couple of these attached to the wall?
    foot pads
    wwaswas
    actually, not the plastic bits but the base plates.
    grizzlygus
    Yeah that’s what I was thinking wwaswas, although I don’t really understand the question. Here’s steel version :
    http://www.amazon.com/Bil-Jax-0030-116-Scaffolding-Rigid-4-Inch/dp/B00004TRCA
    cbike
    Key Clamp – http://www.flints.co.uk
    brack
    That is the idea but I remember there was a neat circular clamp/collar that sits around the pole and is then screwed to the wall.
    gary
    As cbike says, google key clamps and track down a local supplier. They do all sorts of different fittings for mounting stuff between walls or out from walls. I’ve used it to put a bike hanging rail along the wall of my garage.
    midlifecrashes
    If you have a decent drill or a core bit, just put a hole in either side, feed the pole up and repoint. You won’t get a cheaper or stronger way.
    brack
    FlangtasticCheers guys….
    grizzlygus
    I think a standard scaffold tube is 48mm dia Brack
    brack
    Yeah….managed to snaffle some 42.4 scaffolding that was knocking around at work….which whilst narrower is perfect for the job.
    Appreciate you looking out for me! Cheers mate.
    BigDummy
    This is collossally useful chaps, I am trying to do the same thing. Ta all.
The topic ‘Attatching scaffold pole to two walls….’ is closed to new replies.
