Viewing 7 posts - 1 through 7 (of 7 total)
  • Asus Transformer not charging.
  • mactheknife
    1 month out of warranty 🙁 seriously.
    I don’t know anybody else with the same charger, but i have connected the tablet via the USB lead to my laptop which works fine to transfer files so i assume that’s not the lead that is faulty. The charger itself also charges my ipod with a different USB cable so again i can only assume it is the tablet that is at fault.
    So i got onto ASUS customer services stating i was willing to pay for repair costs if they are at reasonable price. Mmmm £35 quid for their courier to pick it up then any repair costs on top of that. I think not.
    So what options do i have. Try and take it apart and hope i can spot something amiss which is bloody unlikely??
    iainc
    Edit, didn’t read your post properly, sorry
    mikey74
    I have a Transformer and IIRC it doesn’t charge via USB, only via the plug adapter.
    mactheknife
    mikey74, i knew it would not charge via USB, i was testing that the laed worked.
    mikey74
    • The Transformer cannot be charged via USB when it is connected to the keyboard dock & when charging via USB will charge slowly at around 3% per hour.
    Edit: Have you looked at the connection into the adapter? Mine wouldn’t charge and when I looked at the adapter end, the cable wasn’t properly seated.
    jonk
    It might have fluff in the plug use a new tooth brush to get the fluff out.
    Cougar
    Or a lungful of air.
The topic ‘Asus Transformer not charging.’ is closed to new replies.
