Are there any arm p...
[Closed] Are there any arm pump reducing exercises?
[#3870035]
We’re going to Morzine again this summer for a week of DH fun, but we’re going fairly late in the season so the breaking bumps will be at their worst. Are there any exercises I can do to help my arms last more than a day? Thanks.
Posted : 14/04/2012 1:52 pm
Slow smooth pushups was always the recommendation for motorbicyclists, worked well for me.
Posted : 14/04/2012 1:53 pm
Advice here:
[url= http://www.vitalmtb.com/features/MTB-Strength-Training-The-Cure-for-Arm-Pump,70 ]Arm Pump[/url]
I found that chin ups helped me massivly
Posted : 14/04/2012 2:13 pm
I only get arm pump in my left hand 😉
Posted : 14/04/2012 2:16 pm
 deus
A bit of a cheat but take an ibruprofen or two before you go out every morning, after breakfast.
Posted : 14/04/2012 2:23 pm
Masturbation, alternating each arm - that way it's like someone else is doing it every other time
Posted : 14/04/2012 2:24 pm
Can't believe you'd cheat on your own hand 🙁 No morals left in the world.
Posted : 14/04/2012 2:25 pm
Although I do suffer from aching hands due to vibrations, I don't really suffer from arm pump and I think this is due to my climbing. Therefore, I think climbing type exercises would be good as there's an obvious crossover where bikers and climbers try to delay "getting pumped".
Things I've used include; Power Putty, Gyro-balls, Black Diamond Doughnut (a rubber ring you squeeze), reverse curls (arm and wrist), squeezing a punctured tennis ball, and "Hectar the forearm correcter" which I made from a rolling pin, sash window weight and length of cord. Wind the weight up in a very slow, controlled manner (elbows locked into your side), then unwind and wind up in the other direction. This is the best exercise I've found.
HTH
Kev
Posted : 14/04/2012 2:29 pm
Relax and brake less.
Posted : 14/04/2012 2:30 pm
+1 for rock climbing.
Also try using a broom handle, with a rope through it, and a weight attached too this.
Wind it up, then down and continue this way until its reached the top.
Repeat.
Edit. Beaten to it.
Posted : 14/04/2012 2:33 pm
