p.s. anyone thinking they need 150mm or whatever travel because they bottomed out once or twice and thus would be bottoming 100mm forks all time has fundamentally misunderstood how suspension works/should be set up.
Not really, you can't get the same shock absorbtion from a 100mm fork (over the same piece of terrain) as a 150mm fork as you'd have to have firmer springs to give less travel with the same impact force, which means the ride would be less supple. We all know forks should be set up to bottom out every now and then, but saying there's no need for 150's because you're bottoming 100's a lot (assuming they're set up correctly) is nonsense.
