Should be easy to tell. From that DT Competition link
“This is one of the most versatile spokes in the DT Swiss spoke range. DT competition® gets its special strength from cold forging. This makes it not only extremely durable but thanks to the thinner middle section, it is 48 g lighter than a spoke with a constant diameter of 1.8 mm. The balanced relation between strength and weight of its 2.0 mm counterpart allows for a wide range of uses,from road wheels to super light enduro MTB wheels”
If the spoke is 48g lighter than it’s unbutted counterpart, over a 32 spoke wheel that’s 1.5kg – and that’s just the difference, not the total weight of the spokes let alone rim and hub. If you can’t physically pick your wheels up, they’re plain gauge
(yes, I’m sure it’s a typo)
