Geax…on a stans…..no chance
This.
If they’re the TNT ones, it just wont work.
Stans rims have a large ERD, so they make non-tubeless tyres fit tight, so they don’t blow off the rim or burp when riding. The problem is, tyre manufacturers also try to solve this problem by making their tyre’s ETRTO small (the internal tyre diameter), so when both the rim maker and an tyre maker try to solve the same problem – they give the customer a problem.
I wouldn’t recommend forcing them on, as they’ll be too tight and eventually the bead will bend, and the tyre will blow off the rim. You’ll have a broken tyre, and a spooged over wall, at best.
