ghetto, with a bmx tube, get’s you a tyre that bonds with the tube ( a bit ) which can be more resistant to burping.
fit inner tube to wheel. i buy mine from merlin, schwalbe ones that have removable cores.
cut around the outside diameter of tube and flap it open.
wash off the chalk powder.
wash the tyre out ( soapy water ).
fit tyre over tube so you have the tube hanging over the side of the rim.
do your best to get the tyre spread.
remove valve core and spaff a load of air in there fast – compressor or ghetto inflator device of some sort.
let it down slowly.
squirt stan’s sealant in through the valve.
spaff a load of air in there fast.
stick valve back in ( don’t have the valve at the bottom ).
wave tyre around a bit, flip it over, bounce it around. some tyres may need to sit for a bit as the walls seal.
if you have to open the valve at any time to put more air in, don’t have it at the bottom of the wheel where the sealant can run to it. put it at 9 or 3 o’clock.
carefully trim around the rim with a scalpel.
buy:
schwalbe sv6 inner tubes.
stan’s sealant in volume of your choice.
some method of squirting sealant through valve ( small stan’s bottle is re-useable ).
SHARP blade.
spare valves ( these can be pinched off spare tubes ).
weldtite tubeless repair kit for if you get a big hole ( keep you thumb over the hole until you can get a plug in there ).
don’t run super light tyres, unless super light yourself. 🙂
