Viewing 29 posts - 1 through 29 (of 29 total)
  • Anyway to check whether a spring is Titanium or not?
  • paulrockliffe
    Got one for sale on a bike and just thought that the only reason I ‘know’ it’s titanium is that the previous owner told me it was. Can I check easily? Don’t want to cause problems down the lines if it’s not ti!
    racing_ralph
    magnet
    paulrockliffe
    Ah yes, good plan!
    GW
    unless it’s painted it should be pretty obvious
    Nicknoxx
    A magnet might prove it’s not Ti but won’t prove it is, as loads of materials, stainless steel for one, aren’t magnetic.
    HoratioHufnagel
    can you submerge it in water to measure its volume, weight it, then calculate its density?
    oldgit
    Cut it in half with a grinder. If the sparks are yellow it’s steel. If they’re white it’s Ti.
    Don’t actually do that coz I might be wrong.
    neninja
    I’ve never seen a painted Ti spring only some heat treated ones that go rainbow.
    If it’s painted I very much doubt it’s titanium. If it’s titanium, the spring will probably have a slightly matt/dull grey appearance.
    Post a picture
    thomthumb
    never seen a stainless suspension spring. does anyone make them?
    wwaswas
    I use a polished brass spring for that ‘steam punk’ frame look so my bike would fail the magnet test too.
    paulrockliffe
    coolhandluke
    +1
    julianwilson
    usually fewer coils for a given spring weight in a ti spring. Unless you weigh 20 stone, the one in the photo looks like a steel spring painted grey.
    ir_bandito
    what julian just said.
    that’s steel.
    skidsareforkids
    That’s just the standard 5th element steel spring I’m afraid….
    Holmesey
    buy another Ti spring and also a steel one. then put your spring in your right hand and pick the others up in your left hand to see which is most similarest. then try to sell your two buckshee springs on here to other ppl with the same Ti spring conundrum
    HTH
    Pieface
    Ti melts at 1650, steel at 1300
    schrickvr6
    Ti springs make vampires eyes water!
    goog
    Specsaver’s?
    ahwiles
    if it’s heavy then it’s probably steel, if it’s 100grams lighter, and cost £200, then it might be titanium…
    Holmesey
    I went to an interview last week wearing a painted steel spring round my neck
    the bloke in Top Man swore it was a Ti e
    xiphon
    Standard 5th spring, sorry
    skiboy
    only non-magnetic stainless is non-magnetic, plenty of magnetic stainless around,
    i’m +1 for the displacement caluculation method too 😀
    scruff
    Nice frame, good look with the sale. Good thread idea for druming up further interest aswell. 😛
    antigee
    depends on the type of stainless steel – 2 basic types
    austenitic (to keep it simple contains Nickel as well as Chromium)most common type as good corrosion resistance and is non-magnetic
    Ferritic stainless steel contain less (or no) Nickel and are hardenable through heat treatment and are commonly used for springs – so expect a stainless steel spring to be magnetic
    molgrips
    If you take it off it’ll be obvious, it’ll feel much lighter than you were expecting.
    paulrockliffe
    Some good answers, the obscurer the better please. (Even though I know the answer now)
    Genuinely wasn’t a way to publicise the sale!
    messiah
    This is what happens when you go outside with a Ti spring.
    toys19
    +1 Horatio.
    In the absence of some fancy kit then the density method is the way to go.
The topic ‘Anyway to check whether a spring is Titanium or not?’ is closed to new replies.
