I did and it didn’t end well.
I used them with Specialized Roubaix 23/25 tyres (23 mm-like contact patch, 25 mm overall width). It was a tight clearance but could be set up ok. I had a 1-2 mm gap underneath the brake caliper where the mounting plate went and a small gap either side of the tyre where the braces met the fender.
The gap underneath the clips wasn’t big enough – debris and flex meant that the underside of the clip wore and the spring was destroyed! Have a look underneath the clip – the grey lever/button relies on the underside of the plastic clip housing to spring back. This is what wore out.
Now I’ve gone to some Schwalble 23 mm tyres and have LOADS of clearance, but suffer from occasional pinch flats in return (the roads round here have a lot of grit and debris)!
