Got the Super Enhanced gps, works well, battery life appears to be superb – I’m getting less drain than 10% for 3 hours (although I don’t often use the hrm, that will use more battery).
The interface isn’t as ‘nice’ as the Garmin, but I suspect it is the same just looks different – the Garmin can show a large number and 2 or 4 smaller ones, the Lezyne splits the screen equally.
The sync to phone to upload is good – mine doesn’t sync to Lezyne so no idea about the routing/making stuff but I don’t use that anyway.
I sync to phone and then upload via phone Web browser to Strava.
The Garmin will alert you when you start moving, Lezyne doesn’t so if you forget to start to record, you don’t get an alert.
The hrm works fine, the phone connection has been not bad but I’ve had to reconnect it about 4 times since I bought it about 5 months ago…seems to be sorted again now.
A good unit, I’m happy with mine.
