Just ordered some 50mm x 3mm neoprene off ebay as a chain stay protector. Only 70p /ft! Got a Orange 5 type swingarm and sticking a strip to the under and inside of swingarm seems to be less unsightly than a large wrap round band. Not sure how it will stick, and stand up to mud and wet, but I've read on here people using sticky velcro instead.
Bike Forum
Anyone tried sticky backed neoprene as a chain stay protector?
Posted 4 months ago #
The glue will most probably be wweakend by the lubricant on the chain, along with your feet catching it, with the tube sort it can revolve
Posted 4 months ago # -
I've done much the same thing on my Turner - seems to be holding up well so far.
Couldn't you slide some innertube over it, & cut out the visible side.
Road bar tape works very well and can be had without a gluey line down the middle. It's also available in most colours as well as clear: no glue issues and weighs nowt!
innertube, wrap and cable tie each end - pikeytastic
As I said on another thread "Use Scotch 2228 Moisture Sealing Electrical Tape. It's a black rubber tape, I found out about it from Mountainbike Action's Jan 2012 issue. I was able to buy it at Lowes home center in the US, but its available online http://www.amazon.com/Scotch-2228-Rubber-Mastic-Electrical/dp/B001ULCB64"
550 cord.
The 2228 tape looks interesting - but hard to get hold of.
I'll wait till the neoprene turns up and give it a go. I'll be sticking it on top of helicopter tape, so if it needs to come off, it should leave the paint behind. I hope.
I've used the Velcro just recently t fitted perfect and thought it stuck down great, but after 3 soaking wet rides t had come off underneath, the inside of swing arm was stillvsecure but the underside had come undone....I've totally dried it and put some supercstrong super super glue under it this time and 1 equally wet ride it's stayed on, it much better looking than a lizard skin thing and does a great job...getting it to stick is the main problem but so far my super glue is working a treat
im still working my way through old inner tubes, carefully wrapped and cable tied at one end
pikeyalltheway
The Scotch 2228 tape is also known as self amalgamating tape, available in lots of places.
Can't say it matters about brand, as it will get chewed up anyway, but is easy to relace.
Screwfix link below.
http://www.screwfix.com/p/self-amalgamating-rubber-tape-black-19mm-x-10m/87717?cm_mmc=Google-_-Datafeed-_-Sealants%20and%20Adhesives-_-Self-Amalgamating%20Rubber%20Tape%20Black%2019mm%20x%2010m&gclid=CIidgKjarK0CFVQLfAod0AOzmAPosted 4 months ago # -
I find adhesive velcro works the best... Some disc brake cleaner on the frame first and wrap it up with masking tape overnight and it stays put for ages! On my 224 because the weld runs along underneath the swingarm i used some clear laquer along the edges and it worked perfect too
Self amalgamating tape works if you have awkward shapes or corners to go round, but the chain still cuts it to shreds.
Sticky backed velcro works well also, but the chain will still go through it.
I use a combination of the two on my DH bike, on my little bike, Santa cruz kindly use some leather/rubber compound thats moulded into the swingarm on the Nomad & it does an awesome job - the bike is near enough silent.
Reply
You must log in to post.
