dovebiker – Member
In a word: DON’T – unless you fancy snapping your frame / bones in your body. Frames need to be reinforced to deal with the extra stresses from the disc brake (never mind trying to find a 130mm OLN disc hub if CX). I know an ex-pro who bust his collarbone first ride having had disc mounts brazed to his steel frame which resulted in a broken seatstay – a similar outcome awaits.
A bit hysterical there… As I’ve shown, a similar outcome in not a given. I also know several people who’ve used adapters with no problem.
As I said though you need to carefully consider what frame you’re putting it on and a carbon one may well be a bad choice as I explained.
And FWIW, with a steel or aluminium frame, you can typically fit a 135mm hub in there without much problem and without them exploding in a ball of fire as I expect might get claimed. On carbon, again, you may need to consider more carefully depending on the design.
