I just changed from 2 x 10 to 1 x 11, for racing and general riding.
Its worth doing some research on what gear ratios you currently have and what you would loose by going 1 x 11 (Sheldon Brown gear calculator online, sure theres probably others). I found with my 2 x 10 set up I really only had 13 gear ratios, I used 1-3 on the granny, then onto the big ring from then as the other 7 gears on the granny are double ups (ie 4th gear was pretty much the same ratio as 11th gear). Whilst 7th gear (3) might be slightly lower than 14th (3.1) I never dropped onto the granny and up 3 on the cassette to find it (maybe some people do).
Hence for me the difference between 11 gear ratios and 13 ratios is negligable and I don’t notice it at all – plus the weight saving loosing a shifter, cable, mech and double to single crankset helped offset any slight percentage differences between gear ratios.
Also with the SRAM cassette 10 – 42 you don’t really loose any upper or lower gear ratios, running 2 x 10 (26:38 front 11-36 rear) I had ratios from 1.4 to 6.7, running 1 x 11 I have 1.5 to 6.4. With the Shimano cassette you will loose out somewhere, either top or bottom end – shame cause I generally preferred Shimano previously.
Very happy with the SRAM 1 x 11 set up, planning to convert all my bikes now. For me, its the best change to mountain bikes in years.
