Hit a pothole, wheel still perfectly true but has lost tension, a quick re tighten us fine so no broken nipples or busted spokes.
But I don’t know what tension it should be, user guide says 85-95kg front wheel and 110-125kg rear DS.
I have a park tool tension meter TM1 and the chart.
But I can’t easily measure the spoke size, all I have is a ruler…which I think gives me a size of 3mm by 1mm but I can’t really tell. This size isn’t on the chart.
If you have a TM1 and the carbines could you do me a massive favour and measure the tension on the meter?
If not and you know the definitive spoke dimensions that would be a massive help.
(I’ve seen you can buy spares, but so far I’ve not located a site that tells me the dimensions, I imagine it is some where in the googleverse)
