• This topic has 2 replies, 2 voices, and was last updated 7 years ago by JAG.
Viewing 3 posts - 1 through 3 (of 3 total)
  • Anyone knowledgeable on stoves, fireplaces, hearths?
  • B.A.Nana
    Is it usual to measure, have cut, buy and install the slate hearth in this state. Or do I wait until after the walls have been rendered and the fireplace firewall plasterboarded? Or is it OK either way.
    perchypanther
    Yep. Burny! Don’t touch.
    JAG
    I measured, and installed my slate hearth whilst my fireplace looked much like yours does – although minus the pile of rubble where the hearth would fit. It was half a dozen large slate tiles sitting atop a concrete base. I then plastered down to the hearth and fitted skirting outside of the fireplace aperture.
    Inside the fireplace aperture I covered the vertical surfaces with fire cement all the way down to the tiles and the Stove kinda obscured the area well enough for it to look very nice. This area was especially well obscured after I’d piled up fire wood in the area’s to either side of the Stove.
    Like this but wood was both sides of the Stove and my plaster ran up to the aperture…
The topic ‘Anyone knowledgeable on stoves, fireplaces, hearths?’ is closed to new replies.
