• This topic has 28 replies, 21 voices, and was last updated 15 years ago by DrJ.
Viewing 29 posts - 1 through 29 (of 29 total)
  • Anyone know how I can find the altitude of my house?
  • Gooner
    I want to set the altitude on my suunto watch
    grid refs are SE 37930 36412 (WGS84)
    thanks
    AlasdairMc
    Ordnance Survey get a map and use the contour lines?
    mistermouse
    find your house on google earth, it should show the elevation
    IanMunro
    322ft
    neilb67
    About 97m.
    Stu
    [Norn Iron voice]
    I know where you live!
    [/Norn Iron voice]
    iamsporticus
    99m
    Whats that boozer like?
    Gooner
    boozer poor but organic ale at £1.40/pint is ok
    johnhoo
    do you have a Garmin device of any variety?
    Gooner
    i do but i am not sure how accurately it has been caliberated
    cbike
    go to a beach, set it to zero.
    Chalkyslide
    Type your postcode into the following ordnance survey site and zoom in on the map until you can read the contour lines….
    http://www.ordnancesurvey.co.uk/oswebsite/
    Flaperon
    Google Earth is your best bet.
    If you use a barometric altimeter you can get the local pressure setting from a nearby airport. Remember that at your elevation and considering the colder weather you might want to subtract about 20 feet.
    Strangelove
    Dont use a sat nav. My phone came with Copilot installed and it claims that bournemouth prom is 110 feet above sea level
    sockpuppet
    you’ll need to get used to checking the height of a point on an OS map and resetting as the weather changes, since pressure altimeters rely on a datum being accurately set. not that often, but certainly from day to day if you’re going to use it to aid your nav.
    surface pressure (QNH) can vary widely: typically 970mb to 1030mb at sea level are not uncommon, with 1013 being a standard day. each mb makes 30ft of difference
    pomona
    QNH is sea level pressure, QFE is surface pressure.
    I’ve seen pressure changes 4 times in an hour (that works out at 120ft) so you need to change it more than just daily if you want to accurately measure altitude.
    mikewsmith
    A map
    Flaperon
    [pedant]
    QNH isn’t sea level pressure, it’s the QFE mathematically corrected to sea level assuming standard conditions. QNF is the QFE mathematically reduced using actual conditions.
    [/pedant]
    pomona
    Flaperon, QSY off to pprune, where people may care.
    GlenMore
    As above – you’ll need to constantly reset the altitude. On a typical days spring or autumn walking in the Scottish Highlands, I’ve had to do this up to 6 times. However, if you know you’re altitude and it changes while you’re stationary (e.g. overnight) this can help identify incoming weather.
    soma_rich
    Look on an OS map and see if there is a BM (Bench Mark) near you?
    Spesh99
    I used Google Earth and found I am at 197 m (646 ft). Who lives the highest?
    matthewjb
    Or an earthquake…
    GlenMore
    Spesh99 – are you my neighbour?
    Spesh99
    Don’t think so I’m in Balerno in Edinburgh. I almost live in the Pentland Hills.
    wwaswas
    I’ve just checked and my house starts at ground level and goes up about 30ft.
    GlenMore
    Spesh99 – Member
    Gulp! Where in Balerno?
    Spesh99
    Why where are you? Click my name and email me if you wanna know where I am.
    I live in Holland so I’m willing to bet it’s not me.
The topic ‘Anyone know how I can find the altitude of my house?’ is closed to new replies.
