Noticed at Rheola yesterday that I was only getting 130mm of trvel out of my 888s, so have had them in bits today to see whats what. They felt the same as they always have, nothing had changed, but realised I’d not been getting all the goodness.
When I got them I was told they were 2005 888r forks of the 170mm variety (also available in 200mm form) with a light spring. They felt pretty decent, so have never bothered to take them in bits before. I did realise they’d been tinkered with as they have compression damping adjustment. On inspection they’re 2004 internals and the spring is the firm one. They’re in very good shape, no problems, so suspect the correct shock and new oil will sort them out.
So why am I telling you all this? Well, I recently emailed Marzocchi to find out if I could turn them into the 200mm forks and was told that the travel is limited by the travel in the pushrods, so I would need new compression and rebound cartridges. No one sells has any in stock and they’re 90 notes each, so that’s a no-go, cheaper to replace the forks. But, the pushrods have 190mm of available travel.
Are they the 170 or 200mm variety? I can’t see why they wouldn’t have 190mm of travel, given that both varieties use the same springs. Wondering if the Italians said they were 190mm, then someone converted that to 8″, then someone else converted that to 200mm or something equally random.
Anyone any ideas?
