there’s something not right about Nest – all feels a bit stealth populace control type thing (keeps tinfoil hat on).. Good kit, but my god it’s expensive..
I called the fire brigade and got free smoke alarms installed.
What makes these different? If there’s fire or smoke they make a noise no?
They alert your phone if they go off (eg when I’m at work) and they detect movement, so I can see if someone is home when I’m at work. They also glow nicely when you walk underneath them at night. They also detect Carbon Monoxide as well, so one goes in the Kitchen with the boiler and the other next to the wood burner…
have you read up on them? I think they are an excellent idea as they can help guide people out of a building safely amongst other things. Maybe not much use for everyone but it definitely has uses.
Will you know if it’s a confirmed fire or not? Or just an indication of alarm activation? All I can see is another increase in false alarm calls.
You’re at work phone tells you it’s gone off, then what? Do you call FS or do you rush home?
Seeing more and more of these types of call outs, “aye at ma work canna get away, but ma phone says the smoke alarm going off, mine and pop round with yer lads and see if there is a fire”
Just a matter of time before fire authorities start to charge for this…….
I was gonna say the same. £90 each against the 6 I got supplied and installed for free. I’m glad I called.
Sometimes you can get a bit too much technology.
Google have to recoup their $3.2 billion somehow 8)
You are aware in this world there are ‘things’. Sometimes you get ‘things’ which have a similar core function. Yet one ‘thing’ may also do extra things than a standard ‘thing’. For this ‘thing’ to do these extra things, the ‘thing’s’ manufacturer will charge a higher price. You should know, that you do not have to pay this extra price, as ‘things’ with the core functionality exist for you to purchase….or in your case, to be provided FOC.
The bottom line is, Footflaps is going to get a text when his missus burns the toast.
So even more google spyware.
They will know what time you go to work, come home,how many people in the house, whatever other big brother shit they can think of.
And you pay £90 each for their spyware that also detects smoke and CO.
Nice work Google.
On this occasion I’m out.
[url=https://flic.kr/p/oDWfYj]Nest up and running[/url] by brf, on Flickr
Slight pain to install, I went for mains powered and expected flush connections, so had pre-drilled a small hole for the power lead:
[url=https://flic.kr/p/oDVyS8]Crimped mains lead[/url] by brf, on Flickr
Only NEST had a stupid bulky proud connector:
[url=https://flic.kr/p/oDWgoh]Power connector sticks out[/url] by brf, on Flickr
So I had to make the hole larger, which with lathe and plaster ceilings is a very messy job…
[url=https://flic.kr/p/oDVyNR]Needs a bigger hole[/url] by brf, on Flickr
Then the iPhone App kept telling me it hadn’t got mains power, so I had it on and off loads of time checking. It wasn’t until I gave it a real smoke test that the iPhone App seemed to sync up properly and decide it was powered after all…
[url=https://flic.kr/p/oUoDX7]Nest iPhone App[/url] by brf, on Flickr
In conclusion though, just having that funky blue ring glowing at you is worth £90, let alone whether it actually works…..
One thing I didn’t realise was that the old CO alarm was out of date, they only last 5 years apparently then you need to replace the whole unit (not just batteries). Only in taking it down did I see the DO NOT USE AFTER date on it…..
Always had a smoke alarm in the kitchen and never had any problems with it. Plus the nice thing about NEST is it doesn’t just go off, it talks to you e.g. she will say “Smoke detected in Kitchen” and then only goes into Alarm mode if it gets really bad and you haven’t silenced it in the mean time. All the NESTs in the house sync up so you hear the voice in every room…
An ex-collegaue just emailed me about this company, which basically turns a normal dumb smoke alarm into a smart one by just changing the battery. Their battery contains a Wifi chip and a Li-ion battery, so it can contact your smart phone when the Alarm goes off / battery gets low.
