Yup, I’ve got one. It’s an elegant idea which probably could do with some improvements.
It won’t work with a MTB triple – the granny ring mounts interfere with the external part – even when I ground them off an old crank 🙁
So I got the cheapest road HT2 double I could (a Sora) and that’s fine, although gauging how many spacers is needed is a balance (on my frame – an XTC) between a crank rubbing the chainstay and not enough axle for the non-drive crank to clamp on to.
It works better than my Surly chain tensioner when the going gets really muddy, and after all that’s usually when I ride the SS as it keeps me lazy on the cleaning. For other conditions, and if you don’t mind a potentially vulnerable part, a tensioner is as effective (and cheaper).
