I have emailed them a couple of times, as after a little bit of “simple” advice on what size headset to order, but never had a reply.
Cant find a phone number either….
My frame according to the manufacturers spec sheet has a head tube length of 149.9mm, so I ordered the set 6 for 150 to 159mm head tubes.
However when I measure it with a tape measure, along the frame taper (so not straight, the head actual head tube length should be sorter…) it measures 148mm
Would [they] recomend I get set 5, for 140-149mm head tubes
or set 6 for 150-159mm head tubes.
Do I need to send the one I ordered back, for set 5, or wont it matter….
Any advice or alternate contact details for works components appreciated….
