So I have a set and realised the 15mm qr axle/lever is an akward bugger.
Whilst out yesterday I noticed that I was getting front sideway wobble especially under power.
As far as I’m aware I always remove/install bike kit correctly as we do when we spend hard money and are naturally anal about doing things the right way.
So when I get back from ride, I notice what seems to be a 4mm side to side play in wheel, more than likely less mm in side to side play but just a guestimate.
So my immediate thoughts are Hope bearings but can’t be as it’s only covered 50 odd miles so far. Removed front wheel to find no obvious bearing play.
Phoned lbs who built them so going in soon to eliminate the hub bearings.
I did noticed 2x allen bolts which constantly wiggle free a tad at lever end of 15mm axle.
Is it safe to apply some loctite to those 2x pesky allen bolts.
If you’re familiar with the Dizzy forks, you’ll no doubt be aware that there’s a part between lever and leg which gives adjustment of lever angle. That bot peeves me reet off as it sliws the process of installation and removal.
Any feedback on what’s going on as it’s not so apparently obvious to my untrained unengineerial brain.
