Size is large with the Reilly fork, cables guides allow me to run a full length gear outer so more reliable over winter, and no front mech as it’s 1×10.
I’m impressed. Angles are nice, finishing is very good. I’ve swapped the stock rear thru axle for a bolt-up version (by MTZoom) and may swap the front too. Rear caliper is PM but the front is flatmount, so I needed to buy a new caliper.
Stiffer than the Airborne Carpe Diem it replaced, so better on the descents/faster corners. Full build is 8.6kg but that’s with carbon rims. Winter spec will be alloy rims (Archetypes) so a few grams heavier, and a rear ‘guard.
