Base of 4th metacarpal in one hand and distal phalange on index finger in other hand. BPW back in April.
As for no use getting an x-ray, well what they were checking for was any displacement of the metacarpal as it was shoved by the adjacent finger. Surgery was likely if it had. Turned out it was fine and they weren’t bothered much by it then.
The index finger was more of an issue as the x-ray showed it up as an avulsion fracture, which is where the ligament has ripped off a bit of the bone. Needed splint to be worn for in theory 8 weeks to ensure it wasn’t damaged further.
The index finger went unnoticed at first and I just commented later that it was swollen and they looked alarmed when they saw it so x-ray straight away.
Anyway, going through all that, you then get the fracture clinic follow ups and finally offer of some physio. In my case I needed it, and really could do with more beyond the freebies they give me. Big thing is with finger fractures you can have ligament and tendon damage or the healed bone grows a larger chuck of bone than before and ligament/tendons have to be worked on to slide properly over said bony chunk, not to mention have generally seized up over time following injury. At least that’s what the physio was telling me.
Oh and I’ve done the scaphoid in one hand also. At least I think that was it. They didn’t really say which bone, but x-ray I’m sure was scaphoid. That’s an easy one, but needed a cast in my case. Still gives me gyp occasionally over a decade later though.
