Hi
as far as I can work out (and I may be wildly wrong)
Mains (blue pipe) connects to directly Prostel (thankfully with a stopcock inbetween).
Prostel then supplies both hot/cold to flat.
so
1 – does that sound right
2 – if I want to turn off the water to the flat (so can do plumbing) what is the process.
*Bits that are ‘worrying’ me are that the overflow (seperate small tank up on the wall) seems to have to be pressurised to 3 bar [ and I have no idea how to do this and don’t want to knacker that).
Do I need to drain the prostel (it has a drain cock but needs to be switched off for drain to avoid overheat – and presumably draining it will knacker the 3 bar header tank pressure ?
Or if I just turn off the mains does the lack of pressure stop both cold and hot flowing ?
Ta
