Let’s assume the document is called ‘membership_form.doc’ –
Upload the document to the webspace and make sure you have the URL for it.
On the webpage you are wanting a text link from, add the following code (in this example anything shaped with <_ should actually be add with the underscore – I’ve added the underscore to make sure this doesn’t do any actual html!)
<_a href=”url_of_document/membership_form.doc” target=”_blank”>Download the Membership Form in Word format (link opens in a new window)<_/a>
This will create a hyperlink to the form with the words – Download the Membership Form in Word format (link opens in a new window) – as the actual link.
You can do the same with an image but instead of using text, you would put the html for an image in there i.e. –
<_a href=”url_of_document/membership_form.doc” target=”_blank”><_img src=”url_of_image” border=”0″><_/a>
