Viewing 5 posts - 1 through 5 (of 5 total)
  • Any tips on straightening Hope floating rotors!
  • postierich
    Kinked one on an off and got sold a dodgy one off classifieds and they are driving me nuts with the on off rubbing any ideas on truing them?
    Rich
    Stoner
    A vice w fibre jaws, some big adjustable spanners?
    Maybe make up a little jig to lay the rotor flat and mark up deflections with a pencil?
    spooky_b329
    Bend the rotor arms not the disc surface. Think truing a wheel via the spokes, not bending the rim.
    brakes
    Put it under you mattress for a few days and use a brand new rotor to compare trueness (truth?)
    Three_Fish
    Not possible on the two-piece rotors. Furthermore, if the carrier is bent on the two-piece rotors, it may not be possible to get them back to true.
    It’s a job best done on the bike, I think. If the rotor was already on the bike and in a working brake, then the pads can be used to center – just spin the wheel and take note of where it goes ‘ching’. Back the rotor out of the pads and use either a proper truing tool or, as already suggested, an adjustable wrench. To bend a rotor back to true, you need to bend it past the point of true so that when relaxes again it is in the correct place. It’s a really simple process once you’ve sussed it out – so much so that it can be done without the use of tools if necessary (clean hands or gloves, obviously).
The topic ‘Any tips on straightening Hope floating rotors!’ is closed to new replies.
