I posted this over on Arbtalk, but thought it might be worth trying here too.
I was using the strimmer today and it very briefly started to vibrate then the head stopped revolving and the revs went up.
I thought immediately that the gearbox had gone at the head. I removed it and it seems to be fine. I also pulled out the long drive shaft and it too seems to be in tact.
When I revolve it inside the long housing there is no resistance at the engine suggesting that clutch has broken. Is this a fair assessment?
I set to removing the cowling at the engine along with the carb. I pulled the four screws which hold the plastic / rubber vibration mounting from the engine, but I can’t seem to split it.
Two questions. Am I along the right lines with the clutch diagnosis? How do I spit the shaft / housing from the engine.
Three questions, a bit like the Spanish inquisitors
Will I need any special tools to remove and refit the clutch?
[video]http://youtu.be/vt0Y39eMvpI[/video]
