Just changed my shock from a fox rp23 to a rock shox monarch rt3 as I got fed up with the pro pedal.
Although I was sceptical about the monarch due to always using a fox and the bad reputation I took the plunge.
I was very impressed. Set at 30% sag to start with. Felt like a hard tail compared to the fox.
Ive got to admit I couldn’t really tell a big difference between the climb, trail and descend mode (rockshox equivalent)
I also found that I bottomed the shock out. i weigh about 13stone with full kit on. Tge shock is a high volume shock.
I’ve been reading about the IFP (internal floating piston) and I have an adapter.
From my limited understanding it separates the air from the oil. Its recommended this should be set at 250 psi.
What affect does more or less psi have?
My aim is to have a shock that sags around 20%
Its a stable platform and doesn’t bob about on the climbs
It goes through its travel but doesn’t bottom out
I can feel a marked difference between the 3 settings.
Any help or guidance other than buy a difference brand shock most welcomed. 🙂
Thanks
