i need help identifying a pipe!
ive got a tank in the loft which has 2 outlets at the bottom. One is a copper pipe which fills the hot water cylinder, and the other is a grey flexibible pipe with a red stopcock on. Inlet and overflow are obviously at the top of the tank.
My cold water is all mains fed, as if i turn off the main cold stopcock in the kitchen none of the cold taps work.
i cant work out exactly where this grey plastic pipe goes as it vanishes down into the walls.
If i turn the stopcock off on this grey pipe (its normally open) it doesnt seem to affect anything, all the cold taps still work and hot water tank still fills up.
Theres a seperate expansion tank for the heating system which has a mains water fill via a ballcock and this all works fine regardless of whether the grey pipe is on or off.
any ideas? It could be to drain the tank, but i cant work out where it would drain to (and the stopcock on this pipe is normally open).
reason for asking is the house is empty and i had a some frozen pipes last weekend when i was over. Mains water was off, and doesnt appear to be any leaks, but to be extra safe i decided to turn this tank stopcock off in case the grey pipe had also frozen and developed leak which would potentially drain the tank while i was away from the house for the week.
