Viewing 7 posts - 1 through 7 (of 7 total)
  • Any plumbers, builders or rabbit tunnel experts around?
  • franksinatra
    We recently got a tunnel thing to connect our rabbits hutch to his run. Perfectly good at what it does but £18 plus delivery! It is this
    I think it started life as a surface water waste pipe and then has some breather holes drilled into it. It is 8 foot long, 5.5 inch diameter. Can anyone confirm what it was before the over priced rabbit shop got their hands on it?
    I need another length of pipe and a way of connecting the two together, could I get such a thing from a plumbing or building store and, if so, what should I ask for?
    tymbian
    French drain. Ie perforated pipe.
    franksinatra
    Thanks
    I’m not so fussed about it being perforated as I can do this myself, just after something I can pick up form a local buildstore type place
    matt_outandabout
    wrightyson
    Where you at? I’ve got countless bits of drainage that could be used for free,
    Stoner
    me too. Anywhere near Worcestershire and I have enough of that spare to make a whackamole for your bunny.
    http://www.drainagepipe.co.uk/products/coiled-land-drain-464/
    franksinatra
    I’m in Scottish Borders.
    Freebies would be good, or I can pay postage. Industrial stuff seems to come in 25m + lengths which is way to much for me. I only need about 4m of the stuff
The topic ‘Any plumbers, builders or rabbit tunnel experts around?’ is closed to new replies.
