I helped a friend build one up with a rear hub drive. It weighted an absokute ton and was pretty badly made (def would not want to get water near it). Was one of those ebay cheap kits.
There are some disc compatible but you will struggle with hydro brakes. Most of these cheap kits are designed for cable brakes. Although you don’t actually need the brake levers (they just cut off the motor power when braking which is kind of useful).
If I were building one for myself… I would definately go for a bafang mid drive with decent battery… But you are looking at 500-600 squids at least for a decent setup.
You are probably best off selling the cube and get a dedicated e bike for the Mrs.
