Viewing 11 posts - 1 through 11 (of 11 total)
  • any one got a pic of homemade headset press
  • robhughes
    hi all
    as above.
    iv,e got a large threaded bar,nuts,spanners but what to use as the washers as not to damage anything.
    also the best way to get the old crown race off.
    is it right to use the old race to tap the new one on.
    cheers all
    mangoridebike
    Not got a pic but I used a couple of coaster type things that stop your sofa marking a wooden floor. wide stiff and plastic so they don’t mark the headset.
    I put a washer in between the coasted and the nut to add a more even pressure to the coaster but this may be unnecessary
    robhughes
    ah good idea
    bridget4
    i made one that works fine from a long fence bolt with a large washer(about 2 inches diameter) at each end – cost just under £1 from local building suppliers
    dobo
    robhughes
    nice one dobo
    pantsonfire
    I havent got any pics but I made a headset press out of 12 inches of studding (threaded bar) and some nuts and washers. The press part I made out of some 9mm MDF I cut circles out using a holesaw. The bottom circle is locked in place with 2 nuts washers and loctite the top circle is loose with a nut and washer on top. I just use a spanner to tighten it down. Yhe first time I used it the cups slipped on the shiny MDF so I cut an old mouse mat up and glued it to the MDF this holds the cups in place while you start squeezing them in. Cost me 50p for the studding all the other bits I had already.
    Coyote
    It’s what I’ve always used.
    pantsonfire
    coyotes latest build 😆
    robhughes
    iv, got a small hilti concrete breaker but thought it a bit severe.
    simonfbarnes
    I use a carpenter’s bench vice:
    (£18.49)
The topic ‘any one got a pic of homemade headset press’ is closed to new replies.
