- This topic has 62 replies, 25 voices, and was last updated 9 years ago by cynic-al.
"Any metallurgists/framebuilders in?" II (al's not giving up)
cynic-alFree Member
Further to my last threadhttp://singletrackworld.com/forum/topic/any-metallurgistsframebuilders-in
I have refined my question to:
What happens to a TIG-welded bike frame when put in an oven at 800°C for 2 minutes from room temperature, then being cooled in air at room temperature.
It seems this will un-heat-treat anything heat treated like 853, but leave TIG joints unaffected (tho wreck any low temperature joints on cable guides, drop outs etc).
So will non heat-treated steel be OK?
redddraggonFree MemberSounds like you are quenching it to me. High temperature and quick cooling. It’s not a cycle I’d treat anything too unless I wanted it hard and brittle.
What are you trying to achieve? Stress relief?
mick_rFull MemberNothing like getting your own information – I’d make (at least) a couple of test samples.
2x 300mm (?) lengths of basic 28.6mm cro-mo seat tube.
2 bits of steel plate.
Tig weld each tube to a plate to give a base / something to clamp down.
Put one through your coating process, keep the other as a control sample.
Do a controlled bending load vs deflection test on each up to failure. I’d use a servo hydraulic actuator to get a consistent rate of loading but I guess that option isn’t open to most people. Plot the load-deflection graphs to find the yield and ultimate loads. This would give some basic information regarding annealing, embrittlement etc.
If doing it properly (ha ha) you would really need to test a bigger batch of samples to allow statistical / weibull analysis of the results.
And maybe then some impact / fracture toughness type tests….
And then different tests with more batches of samples to investigate fatigue performance…..
cynic-alFree Memberredddraggon – Member
It’s the same cooling as brazing?
shandcyclesFree MemberAl,
that frame is going to have a wall thickness of about 0.5 or 0.6 in the middle of the main triangle. You’re going to be heating it up to a bright cherry red for 2 minutes. It’s stupid. But I’m sure you’ll keep asking the same questions until someone tells you to go ahead. Whether it’s been tig welded or brazed makes no odds.
redddraggonFree MemberYou’re heating a thin walled steel component to 800c then air cooling it. Because it’s so thin walled, it will cool really quickly. So yes, you are basically quenching it.
You sound like the mechanical engineers I work with. They ask me questions, and ignore me when they don’t hear the answer they want to hear.
bencooperFree MemberIt’s the same cooling as brazing?
Brazing and welding only affect a small area at the ends of the tubes, and the ends are thicker for a reason. Like Mick says, do some proper tests if you actually plan to ride this bike.
What on earth are you doing, anyhow?
ampthillFull MemberYou’re going to be heating it up to a bright cherry red for 2 minutes
No he isn’t.
I’m not sure how hot steel tubes would get in air at 800 degrees for 2 mins. But I think we can rule out 2 mins at 800 degrees
That’s why the test sound like a good idea
Or even just try an infra red pyrometer on a bit as it comes out of the oven
ampthillFull MemberOK so how would you measure the temperature a piece of steel
I’d put money on it not being cherry red as it comes out of the oven
redddraggonFree MemberI use a thermocouple. IR pyrometers can be 100s of degrees out.
wwaswasFull MemberI just want to see the frame sized oven that goes up to 800c that Al’s building in his spare bedroom.
oliverracingFull MemberBut I’m sure you’ll keep asking the same questions until someone tells you to go ahead.
Go Ahead – It’ll be awesome and I can say so cause I’m and engineer and have built 2 frames*!!!
*out of carbon and have no metal/heat treatment experience 😉
shandcyclesFree MemberNo he isn’t.
In a previous conversation, he told me the frame needed to be heated to 800ºC for 2 minutes. I agree putting it in an 800º oven for 2 minutes isn’t the same thing. I don’t know if he know this.
irelanstFree MemberAssuming it’s in the oven long enough to reach 800°C then what is the oxidation rate going to be? Those thin wall sections in the middle are going to be wafer thin in no time at all.
DaffyFull MemberFrom memory, and in an Argon heat treatment oven (to avoid Ben’s critique) thin walled steel parts cooled from 1200k to 400-450k in around 20-30 seconds. The remaining 150k took a decent while longer.
It wasn’t quite the same result as oil or water quenching as we still saw some bainite formation, whereas with quenching it would’ve been almost all martensite.
cynic-alFree Membershandcycles – Member
Al,
It might be, but I want someone to explain/convince me as to how rather than just say so.. Fancy a go at that?
See above – if all you can say is “because I say so and I’m right” I’d want a better answer.
Daffy – Member
Cheers!
In a previous conversation, he told me the frame needed to be heated to 800ºC for 2 minutes. I agree putting it in an 800º oven for 2 minutes isn’t the same thing. I don’t know if he know this.I’d hoped the fact I’d posted this thread would answer your last comment quite clearly 🙄
So can anyone think outside of their box and answer/explain?
oliwbFree MemberWhat was the final tempering temperature of the material? What are you trying to do with the 800°C???
cynic-alFree MemberDunno, it’s basic non-heat-treated cromoly (yeah I can/could look it up, at work just now)
dragonFree MemberYour asking the question the wrong way around IMO. You should be working out what properties you need from the material in the final condition, look at where the material is now, then design the process to take you from material now to where you want to go.
Some info below robbed from another forum, who know’s if its correct:
Yes, for 4130 you heat, quench (to harden), heat, air cool (to temper) to heat treat it, and yes, this does result in a raised yield strength (the amount of force applied to a section before it gives), but no, it doesn’t change it’s Young’s modulus (which is roughly the same for all steels), in other words, it’s stiffness is he same.
If you do not heat treat the part after welding, the main sections will still have the roughly 72Ksi yield, which is really only marginally better then cold rolled mild steel at 69Ksi (and when you look at acceptable ranges you’ll find that they actually overlap, so real world, the 4130 could be lower), but around the weld joints it will self quench resulting in narrow areas where it is hard/brittle and not tempered, where it will be prone to shattering into sharp pointy pieces. Attempting to normalize it in sections usually results in just moving around the hard points unless you can manage to get the whole structure over it’s critical temperatures (around 1700* and then 1200*) at once.
shandcyclesFree MemberIt might be, but I want someone to explain/convince me as to how rather than just say so.. Fancy a go at that?
Sorry Al, I don’t know why. What I know is that if I heat a 0.5mm downtube up to 800ºc and hold it there for a couple of minutes then I’m pretty sure that frame will break. I certainly wouldn’t ride it.
I know you’re looking for specifics and I’m not able to provide them for you. There is a ton of info out there for you to read but without knowing what steel alloy you have, wall thicknesses etc it might be hard to get actual data.
There’s some really good (basic) info on this in the ‘Machinery Handbook’. I’m sure there’s better and more up to date information available too.
cynic-alFree MemberCheers Steve, I accept your position, you will no doubt that I want to find the facts tho!
dragon – Member
Not possible unfortunately!
Brant said recently that zero/few frames were heat treated post-welding.
I guess I could email Reynolds, I guessed they’d ignore me thinking me a time-waster!
I’ve just emailed you a tech doc from Reynolds, I’m not sure it sheds much light but it might be useful. I’m not sure if that doc is supposed to be in the public domain so I’d appreciate it if it wasn’t shared.
oliwbFree MemberI think (though am an Engineer not a metallurgist) that you’re over thinking this massively. There’s a lot of talk ^^ about normalizing, tempering, quenching etc. Most of this is more related to base materials that you use rather than welding.
I suspect what you really need to be doing is a heat treat post welding to stress relieve. The material condition post-welding is not nearly as much of a concern as the residual stresses that remain in the material after a welding operation. Stress relieving is controlled by time and temperature. As a general rule you want to stress relieve at <50°C below the final tempering temperature of the material batch supplied (you need mill certificates to work this out)…..as a guide the temperature you’re looking for is probably closer to 550-600°C MAX for ~4 hours (the longer the better), rather than 800°C for 2 mins. As others have stated 800°C for 2 mins is more akin to hardening (embrittling the material). 800°C for longer duration’s of time could result in normalizing the steel….you would then need quench and temper to get the strength back – this is the sort of stuff that happens at mills not fabrication workshops.
Oli.
oliwbFree MemberPer above….it’s not the 72ksi yield you need to be concerned about – it’s the 30-40 ksi residual stress around the heat affected zones (caused by welding) that results in early failure. You therefore need to stress relieve – not temper, quench, normalize or anything else that people have mentioned.
Oli.
shandcyclesFree MemberJust to provide context. This isn’t about welding, Al has an old frame that he wants to coat (ceramic? enamel?) I can’t remember, and the process requires the frame being at 800ºC for 2 minutes. He wants to know if this will weaken the frame to an extent that it will effectively be unrideable.
And yes, everyone is overthinking this massively 🙂
oliwbFree MemberWhat’s the coating? 800°C for 2 mins could be an HVOF spray (probably fine), a spray then baked (maybe not fine) or a surface treatment (again probably not fine).
If it was mine…..I’d just get it powder coated for like £20 cash!
Oli.
thestabiliserFree MemberI can see the need, I’m sick of getting baked on lasagne off my bike.
bobloFree Membercynic-al – Member
Shirley not. Whyever would they think that….? 😀
somafunkFull MemberI’ve had a few exhaust manifolds/downpipes ceramic coated (rally cars/fast road cars) to help in under bonnet/transmission tunnel heat control issues but i can’t see the point in getting a bike frame done this way – it’s not really the type of finish that i’d desire in a frame. I’d get a good quality powder coat done by someone who knows what they are doing (bencooper knows a good one)
jaaaaaaaaaamFree MemberSounds like a lot of work/expertise without knowing why. Maybe you should hire a metallurgist for your boutique frame business rather than asking a forum?
dudeofdoomFull MemberErrr isn’t a ceramic coat going to crack if there’s any flex ?
Im sorta with soma funk on this – a quality powder coats lovely and pretty much normal…
ceramics fine if your attempting reentry.bencooperFree MemberI’ve got a copy of Bicycle Metallurgy for the Cyclist in the shop library – if I remember I’ll bring it home this evening.
There are some people doing some kind of ceramic coating on frames – only in the States I think, and I don’t think it’s a baked on finish.
mick_rFull MemberSo can anyone think outside of their box and answer/explain?
If you want factual answers then give facts to base them on! I’ve read cookery books which give more information than your description of the heating process 🙂
Forget the hypothesising – Go measure on a bit of tube. Exactly how hot for how long? And what is the actual rate of cooling? Make some graphs. If you are serious it isn’t that hard.
£20 buys you a 1.5m thermocouple which could be run out of the oven.
http://uk.rs-online.com/web/p/thermocouples/7877841/£12 buys you a K type digital readout from ebay.
And when you’re done you can whack it with a sledgehammer to at least see if it is still ductile and vaguely safe.
If you were armed with some facts and specific questions then I’m sure Reynolds would be approachable. Same for Columbus. Or go to Bespoked next year and talk to Engineers from them both face to face.
To be honest people have been pretty patient – the stw graphic designers get much snottier about giving work and information foc…..
cynic-alFree MemberIt’s not ceramic.
Cheers Ben.
Mick it is literally going into a kiln at 800°C for 2 minutes then coming out (that kiln being at the he other end of the country). I don’t know how much more specific I can be.
irelanstFree MemberWhat exactly do you want to know, I assume how hot will the frame get and what metallurgical effect there will be?
There are still an awful lot of unknowns for people to even attempt to give an answer, I’m not a metallurgist, but I did spend 15yrs designing furnaces so know a bit about heat transfer. So I may be able to help on that part of the problem given some more information;
What are the dimensions and construction of the kiln? What is the configuration of the heating elements? Where will the frame be positioned inside it? What will be supporting the frame? Surface area of the frame? You would need this to calculate the form factor to determine the radiant and conductive (from any supports) heat transfer.
What is the control strategy, zoned? cascade control? Both have a huge influence on how the kiln responds to a cold load being introduced.
What is the coating you’re putting on? What’s its SHC, its emissivity, its latent heat of vapourisation?
Is the kiln purged with an inert atmosphere? If so Argon or Nitrogen based? What flow rate?
What’s the frame material, you mention 853 is it all 853? What are its properties, SHC, Thermal conductivity, density?
The topic ‘"Any metallurgists/framebuilders in?" II (al's not giving up)’ is closed to new replies.
