We have this one, but I think the design is dangerous…
There are two independent lock barrels, so if you deadlock it from the inside (to stop the hand through glass scenario) you can’t then get out without a key and opening it from the outside (to come in) doesn’t unlock the inside handle. Fire escape risk IMO.
You don’t have to use the dealocking function all the time. Arguably you want the higher security when your home is unattended, and obviously it is not an increased fire risk then. When you are at home, you can choose not to deadlock it or you could deadlock it but leave the key in the lock on the inside.
Incidentally it would be a good idea to check your household contents insurance policy document and see what requirements it makes about locks. It might only require that all locks are put into effective operation when the house is left unattended, but it might also specify that the door locks are to a minimum standard, e.g. BS3621, which models 84 and 85 do not meet.
