Had mine 2 years nearly, done a tonne of enduros;local, ews, ukge, mega,local DH races and stuff on it, plus 50 k loops at afan etc
A lockout on the shock helps, I run it 1×10 with a 32 front and 40 expander and it can get me up anything
I’d choose the hardtail for a 50k xc ride, but if there’s some challenging descents then I’ll take the process
It does descend brilliantly, long reach works very well with a tiny stem and wide bars.
Incredibly confidence inspiring, jumps and corners really well
I got basic version to 14kg with lb carbon wheels, slx drivetrain etc
Needed a bearing change this summer, was a bit of a pain but not terrible
Pf bb lasted a year, but xtr replacement seems fine , no creaks or anything
Bad points-
Even with n\w and clutch mech still needed a top guide to stop loosing the chain on rough stuff
Bb is low so 170mm cranks or less
I didn’t rate the monarch rt on mine
Mud clearance at the back is OK, I’ve clogged a few times in very muddy races, but that’s with 35mm rims and 2.4 tyres!
The back end is wide (and very stiff) so watch for heel clearance
