My fuel pump/sender unit has started overheating in the car, its melted or burned a small hole in the inspection hatch above the tank so fuel has started leaking from the tank, as well as tell tale whisps of smoke. 🙁
Need to syphon some of the fuel out as its full, got some clear hose and a big metal fuel can, but on my first attempt with clear tubing I hesitated as the fuel appeared, it ran back slightly so on my second suck I got a lungful of fumes which I don't really want to repeat 😉
Any ingenious ideas for stuff around the house that I might be able to start the syphon with?
I don't want to use anything electrical so that rules out the silly options like the vacuum cleaner, I used to have a footpump for an airbed which sucked but thats gone missing. All I can think of is sealing the hose into a 2 litre water bottle, and then punching a hole in the base of the bottle to drain the water and create a vacuum to drawing the fuel. Drawbacks of this is the neighbours will think I'm syphoning petrol onto the floor, and I'll have to kink the hose, disconnect the bottle and transfer hose to the base of the jerrycan without losing the syphon…
