Home setup is:
Small pc (running Itunes)connected to Home surround amp and Tv
Speakers in all other rooms using Airport expresses…
The Amp is being used as the Airplay as its connected to the PC..and until Apple lets us use Ios to send to Multiple Airports I’m stuck with that…
I turn on all the airports using remote plugs so in theory i can lie in bed turn on all the speakers and the pc from there…wait till Pc starts and loads itunes and use remote on iphone to control library…voila…but I have one slight problem that is bugging me…
My Surround Amp has to be turned on first before the PC or i can’t get the Pc to display on the TV its just a blue screen, if i reboot the pc after amp is on it loads fine and i can use the PC on the TV, no movements on the keyboard etc make the PC appear on screen…
I can’t turn the Amp on remotely..
While its not a massive problem it does mean i have to physically turn the Amp on first which i obviously can’t do from another room…I can still use the sound as the Pc is on but if i then turn the tv on its bluescreen and a reboot.
Anyone any ideas why the Amp must go first to load PC on screen
Thanks a lot
Anthony
