I’m visiting my Dad, who has a much higher water bill (metered), seemingly caused by water flowing out down the overflow pipe from the heat pump. You can see the water through the tun dish. It’s constant apparently and the water is sometimes warm. Pressure looks normal. I suspect it’s a problem with the pressure release valve?
Am I correct in thinking water shouldn’t flow there normally and that it only happens if the release valve is ‘tripped’ or faulty.
I’m not being a tight arse, it’s just that the guy that installed has emigrated and other plumbers won’t come and have a look, as they don’t normally work on these systems.
