explain and critically discuss the importance and management of sustainability in the delivery of sustainable facilities management services
I believe that the importance of sustainability and the management there of, is at the core of sustainable FM services. more critical analysis of the situation will reveal that removing the sustainability from this funtion will result in a non-sustainable FM service.
Equally it can be argued that if you remove the facilitties management from the equation anf focused purely on the sustainability you would end up with a sustainble services but not a sustainable facilities management service.
From this critical analysis of the proposition it is clear that sustainability is critical to the sustainable FM services but that this level of criticality must be managed carefully so it does not remove faciltites management from the equation.
Thank you.
*FM is more that toilet roll in toilets, you need to wipe the plant leaves with a wet sponge once a month too.
